Convert Int to a decimal number
KrisJeff
Flowcode v5 User
Has thanked: 4 times
Post by KrisJeff »
Can someone help with the attached. I want to be able to print an amps value in decimal to 2 decimal places?
ADC_Int_3Expiriment.fcfx
(9.76 KiB) Downloaded 198 times
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: Convert Int to a decimal number
Post by mnf »
In a calculation use:
str = FloatToString$(value, 2) (or change 2 to required number of digits...)
Then print str.. (str defined a string variable..)
KrisJeff
Flowcode v5 User
Post by KrisJeff »
Dear Martin,
Thank you for your help to date. Done as instructed. Now get to 2 decimal places but still printing only the whole number.
Sorry, I'm not very good with string manipulations etc. Please see amended as per attached.
(10.16 KiB) Downloaded 178 times
mnf
Post by mnf »
Sorry - not at computer now.. but is your value a float?
Just looked and it's an integer value - you'll need a floating point value for your result...
Martin is correct.
I have change it for you.
Try the attached Flowchart.
ADC_Int_3Expiriment2.fcfx
(11.09 KiB) Downloaded 181 times
