Ads 1115 16bit adc module
siliconchip
Has thanked: 101 times
Been thanked: 25 times
Post by siliconchip »
Hi all,
Has anyone used the 16 bit ads 1115 adc module with a pic micro ?? If so could you show how you used it within flowcode please, thanks in advance
Bob
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: Ads 1115 16bit adc module
Post by QMESAR »
Hi Bob,
We are currently working on a Flowcode component for the ADS1118 which is basically the same ADC the only (biggest) difference is the interface ADS1115 use I2C and ADS1118 use SPI
You can check on Flowcode Exchange here https://www.flowcodexchange.com/ when this will be ready I guess in around 8 days
siliconchip
Hi QMESAR
Thanks for the reply i take it by using spl this will mean using more pins on the controller over the 2 used on I2C also is there anything already for the 1115 ?
Bob
QMESAR
Post by QMESAR »
Hi Bob
This is true :D
I do not know of any ready component for the ADS1115 in Flowcode.I might be wrong.
after the ADS1118 I will try to do a ADS1115 if there is not a component for it.
Has thanked: 182 times
Been thanked: 179 times
Hi Bob
The component ADS1118 is ready to download. I think it's a very good and fast working Homepage
Hi Qmesar
Thank you for the component.
It would be nice if there would also be a 2khz sampling rate converter
I had a look for one and found some from TI.
2-kSPS, 16-Bit ADC with Integrated PGA and Reference
ADSxxx.pdf
(494.59 KiB) Downloaded 500 times
QMESAR
Post by QMESAR »
Hi Stefan,
Thank you for the datasheet ,I will look at it and order one to do a Converter component for Flowcode
siliconchip
Hi QMESAR,
Thanks are you going to look into the ads1115
Bob
QMESAR
Post by QMESAR »
Hi All
An component for the ADS1115 is available here for free
https://www.flowcodexchange.com/product ... -interface
Enjoy
That's great Martin!
Thank you for creating a component and then sharing it.
I have now got your component and going to order the hardware to go with it.
I will let you know how it goes.
I do like like the idea of your Flowcode exchange.
Edit: I have one arriving tomorrow. :)
