Set up the oscilloscope ¡¡¡SOLVED!!!
Fer_taca
Has thanked: 13 times
Been thanked: 10 times
Post by Fer_taca »
Can someone tell me how to properly configure the oscilloscope that Flowcode has integrated, when working in simulation?
Basically, that they told me how to add the data to be displayed in any of the 4 channels that the oscilloscope brings.
That is, if I have an output with a square wave through pin A1 of in pic, how can I add that pin A1 to the oscilloscope to be able to visualize what the wave shape looks like in the output?
The problem I have is that, in simulation, when I activate the oscilloscope option, it appears on the pc screen but I don't see any option to add the signals to be displayed on any of the channels.
Attached image of the oscilloscope screen that appears on the PC.
Thanks in advance for the answers.
F.
Re: Set up the oscilloscope
Hi, Fer_taca
What Flowcode version (Help, About) are you running?
The scope had a makeover with V8.2, so best to make sure you are running the latest version.
My version is v8.2.2.15
Fer_taca
Post by Fer_taca »
Thanks for the answer Medelec
My version is 8.0.0.6
Regardless of whether the viewer was renewed in a later version, what I do not understand is why, if the oscilloscope option is available, no option can be added to be able to be visualized, unless it is because this version has a bug.
This utility, until now I had not had a need to use it.
F.
I believe the makeover was to make it easier to use?
I would recommend You go to here
Select the I'm not a Robot.
First download and install the patch.
Then finally download and install the hotfix
Finally Use Help, Check for updates.
Then after restarting Flowcode, you can run the scope.
I can then help you further.
Fer_taca
Post by Fer_taca »
Gracias por la respuesta.
Seguiré las indicaciones dadas.
Una pregunta adicional: ¿Antes de los pasos indicados es necesario desinstalar la versión antigua
Si no es así, después de instalar el parche, al realizar la nueva instalación es necesario el realizar la instalación completa o solo una actualización dela versión descargada?
F.
There is no need to uninstall first.
Just download the patch and hotfix.
That will convert the old version you have to the latest v8.
Fer_taca
Post by Fer_taca »
:Gracias por responder tan pronto.
Lo haré según sus consejos.
F.
Fer_taca
Re: Set up the oscilloscope ¡¡¡SOLVED!!!
Post by Fer_taca »
Done according to the indications and everything working correctly.
Thanks Medelec
F.
Hi, F.
That's great!
Thanks for the update.
