When I want to address the 32MX220 as I2C slave I get the following error message.
Flowcode2.o: In function 'main':
Flowcode2.c:(.text.main+0x38): undefined reference to 'FC_CAL_I2C_Slave_Init_1'.
Flowcode2.c:(.text.main+0x54): undefined reference to 'FC_CAL_I2C_Slave_Status_1
collect2.exe: error: ld returned 255 exit status
Error(s) in build
Autoclose turned off
What do I have to do so that the error message does not occur.
Error message with I2C slave and 32MX220
Pascal_2016
- Been thanked: 4 times
- Flowcode2.fcfx
- (11.08 KiB) Downloaded 188 times
Re: Error message with I2C slave and 32MX220
I'm afraid we do not currently support the I2C Slave on the PIC32 range of devices. It's something I can look into for you if you need this functionality.
Pascal_2016
the microcontroller is not so critical, but unfortunately I had to notice that your example for the I2C does not work with 18F25J50, Arduino Nano, 16F1939 nor with 24F16K102. I even get an error message on the master with 18F25J50, Arduino Nano and 16F1939.
The 24F16K102 is at least recognized by an address scan.
Unfortunately, the data that is sent despite the correct address was found is not recognized.
When I use the Arduino Nano with the Arduino IDE, the bytes that are transmitted on the I2C are clearly recognized.
Unfortunately this is not the case with Flowcode and PIC microcontrollers. If you can help me with this problem I would be very grateful.
I have attached the test program
