Hex compile error
alanwms
Has thanked: 4 times
Been thanked: 17 times
Hex compile error
Post by alanwms »
Hello - I'm working with FC5 due to an old program I am updating. A few questions:
1. The program will not compile to Hex - Give me an error 120 telling me about C code.
I do have I block with C code changing the osccon and intcon. I deleted this block, and the 120 error remains.
2. Can this program be imported into my FC9?
I think I experienced the 120 error before, and overcome it but don't remember. I searched the forum without luck.
Can you assist?
FLOWCODE 5 Dracular BUZZ WC100218-1910.fcf
(266.72 KiB) Downloaded 474 times
Re: Hex compile error
Hi.
The attached FC9 version compiles OK for me.
FLOWCODE 5 Dracular BUZZ WC100218-1910_v9.fcfx
(318.5 KiB) Downloaded 479 times
alanwms
Post by alanwms »
Thanks Martin - How did you convert to FC9?
You're welcome.
I have all Flowcode versions from v3.
v6 and V7 allow you to convert the older fcf type to the newer fcfx.
I also had to modify the C code so it's XC8 compatible.
Is the v9 version working for you?
alanwms
Post by alanwms »
The converted file is working for me - A few hickupps, mainly for the analog inputs. I used to have a number in the program looking for <1500. Now that code only works with <500.
I think I have concluded that the FC9 thinks that the pic18f2553 is an 8 bit analog - It's actually 12 bits (4096)
I'm trapping the DC voltage and running an eeprom save below a certain value - My sample voltage is developed from the 17VDC power using a potential divider, bringing me to around 4V. When the DC analog is around 2.5V I presume the power is going away, and Irun the eeprom save routing which saves all my values for next power up - Works great.
I checked the voltage on the AN input and the routine runs at 2.5V which should equate to around 2000 counts. It thinks that 500 counts is around 2.5V.
Should I post this on the V9 site? DId you want to take a quick look at that?
I have the older FC versions too, and will familiarize myself with the conversion process. Thank you
Hi.
alanwms wrote: ↑
Mon Jun 21, 2021 3:11 am
If you post it on the V9 site, it will help anyone else who has v9 and facing the same issue.
I have resolved a similar issue before.
alanwms
Post by alanwms »
Thanks Martin
