Bmp 180
Re: Bmp 180
Hi, mola.ae
Flowcode v9 has BMP280 and BME280
a BMP180 can be created for v9 as well.
Have you thought of giving it try?
You could use the free 30day trial with everything unlocked, and see how you get on?
Re: Bmp 180
Thanks, if it possible to upload example that works in fc8, or fc9 supported bmp180?????
Re: Bmp 180
I will create a BMP180 Component for v9.
I will also inform you when it's on the v9 update system.
Edit: Component has been created & hopefully will be available sometime on Thursday 30 Sep.
Re: Bmp 180
The component is now available within v9.
You might have to change Files in-use to Full database.
I have not got a BMP180 to test it with.
If you could try it out and let us know how you get on, will appreciate the feedback.
