Help with display ILI9341
RLOPES780
Been thanked: 3 times
Post by RLOPES780 »
Good Morning.
Could someone help me with the connections between a dspic333p512mu810 microcontroller with an ILI9341 display. (Note is a Mickromedia kit)
Flowcode pins are MOSI, CLOCK,CS,D/C,RESET,LED. And what are the dspic ones?
Grateful
https://download.mikroe.com/documents/s ... l-v100.pdf
Re: Help with display ILI9341
It looks like the display on the board is setup for parrallel communications whereas the component in Flowcode 7 only works with a serial SPI type display. You may be able to use the display in serial mode but often this is set on the display's PCB with resistors connected to the display driver IC.
Flowcode v9 does support the parrallel drive mode so maybe you could use the free trial and see if you can get this working with the board.
