Migration from PIC16F18345 to PIC16F18444
CamargoF
Has thanked: 6 times
Been thanked: 7 times
Post by CamargoF »
I need to migrate a firmware from PIC16F18345 to PIC16F18444, due to the lack of devices on the market.
I set the new device and I did not make any change in the block code.
The compilation fails, as described below. I believe there is some error in the implementation of the PIC16F18444 code.
I am running Flowcode v8.2.2.15 and the database is up-to-dated.
I appreciate any help.
The first time I tried to compile, only replacing the PIC module (properly reconfigured) I had this error:
FC202230105_3v7A.c: __EEPROM_DATA()
   430:	__EEPROM_DATA('B','l','o','c','k','l','i','n');
	              ^ (194) ")" expected
   431:	__EEPROM_DATA('e',' ','K','O','1','1',' ','3');
   432:	__EEPROM_DATA('v','7',' ','b','y',' ','C','o');
   433:	__EEPROM_DATA('n','s','e','n','g',0x0A,0x0D,0x00);
   434:	__EEPROM_DATA(0x01,0x03,0x01,0x01,0x00,0x00,0x00,0x00);
   435:	__EEPROM_DATA(0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00);
   436:	__EEPROM_DATA(0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00);
   437:	__EEPROM_DATA(0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xAA);
   438:	__EEPROM_DATA(0x01,0x03,0x01,0x01,0x00,0x00,0x00,0x00);
   439:	__EEPROM_DATA(0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00);
   440:	__EEPROM_DATA(0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00);
   441:	__EEPROM_DATA(0x00,0x00,0x00,0x00,0x00,0x00,0xCC,0xDD);
   442:	__EEPROM_DATA(0x01,0x03,0x01,0x01,0x00,0x00,0x00,0x00);
   443:	__EEPROM_DATA(0x00,0x00,0x01,0x04,0x00,0x00,0x00,0x00);
   444:	__EEPROM_DATA(0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00);
   445:	__EEPROM_DATA(0x00,0x00,0x00,0x00,0x00,0x00,0xEE,0xFF);
   446:	__EEPROM_DATA(0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00);
   447:	__EEPROM_DATA(0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00);
   448:	__EEPROM_DATA(0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00);
   449:	__EEPROM_DATA(0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00);
FC202230105_3v7A.c: 450: too many errors (21)
(908) exit status = 1
Error returned from xc8.exe
For some reason the compiling rejects the EEPROM initial values.
I don't know the reason since both PICs have the same EEPROM size.
So, I clear the EEPROM initial values and tried to compile a second time.
Then the compilation fails again, but with another set of errors:
C202230105_3v7A.c: main()
  8927:	PIE1bits.TMR2IE = 1;
	                ^ (255) not a member of the struct/union ""
	                   ^ (182) illegal conversion between types
int -> volatile union S846
  8931:	PIE1bits.RC1IE = 1;
FC202230105_3v7A.c: myisr()
  8990:	if ((PIR1bits.TMR2IF) && (PIE1bits.TMR2IE))
	              (199) logical type required ^
  8993:	PIR1bits.TMR2IF = 0;
int -> volatile union S828
  9003:	if ((PIR1bits.RC1IF) && (PIE1bits.RC1IE))
  9006:	PIR1bits.RC1IF = 0;
I don't understand why the interrupt blocks for TIMER2 and UART are failing.
These pictures shows the block interrupt setup:
This picture shows the configuration I am using for PIC16F18444:
Best regards,
Fernando
Re: Migration from PIC16F18345 to PIC16F18444
Hello Fernando,
Investigating now for you, hopefully should be a quick one to resolve.
Bachman
Has thanked: 9 times
Been thanked: 53 times
Post by Bachman »
I've seen this type of inexplicable errors in earlier versions of Flowcode after same step. I'm not sure what is causing this, maybe some cache problems. Until Benj solve this, try the following:
Start a new project with PIC16F18444, configure the PIC. Open the older, working project, and export every macros one-by-one. In the new project, import every macros. If asked, always use the existing variables, othervise will be duplicated and renamed in the imported macros. If I remember well, the "main" macro can't be exported, so select every icon, copy and paste it onto the new. Check that, you have same variables in the new and old project. Cross fingers and try to compile.
At this point, I don't have better solution, maybe more than nothing.
Bachman
Post by Bachman »
Interrupt errors:
The two PICs have different interrupt table. Delete the interrupt an recreate. PIC changed, contents of interrupt enable, disable and handle code not. Maybe same error with EEPROM.
Hopefully solved for you now via the Help -> Check for updates.
CamargoF
Post by CamargoF »
The library update worked.
Thanks.
Please, close this issue.
