assembler in FC7
DELAK_ALED
Has thanked: 5 times
Been thanked: 2 times
assembler in FC7
Post by DELAK_ALED »
In flowcode 6 I have no problem sending an assembler program to hardware (see example in attachment). However, in flowcode 7 I can't do that. Does anyone know how to modify the program so that I can also use that assembler program in flowcode 7?
Thanks in advance for helping to find a solution.
asm
movlw 0b00000000
movwf _trisd
movlw 0b10101010
movwf _portd
in_FC6.fcfx
(3.12 KiB) Downloaded 324 times
Re: assembler in FC7
Hopefully this post will help:
viewtopic.php?f=63&t=22957
DELAK_ALED
It has indeed helped me a lot. I only have a problem if I want to use a variable in my program.
How can I do that in FC7?
in FC6 this works well
unsigned char test;
asm
movlw 0b00000000
movwf _trisd
movlw 10
movwf _test
movff _test,_portd
in FC7 a problem occurs and it only has to do with that variable
unsigned char test;
#asm
movlw 0b00000000
movwf trisd
movlw 10
movwf test
movff test,portd
#endasm
Has thanked: 187 times
Been thanked: 205 times
In FC7 naming changed to capitals. If I had a variable called "test", I would if using a C-code block reference it with FCV_TEST
HTH
EDIT..
Oops, forgot you were using asm but Steve to the rescue :)
Please see the attached and image below.
It contains 4 equivalent icons showing variable assignment: Flowcode, C code and two in Assembly code.
There are 2 assembly code versions. The first is a copy of how C code statements are converted to assembly by the compiler (I found this by looking at the generated ".as" file after I did a compile). The second is a simplified version, but note it might not work because of various complications in the compilation process (due to optimisations, etc). The XC8 manual has much more information on this.
c code test.png (20.72 KiB) Viewed 21900 times
c code test.fcfx
(7.14 KiB) Downloaded 325 times
DELAK_ALED
Thank you to everyone who helped me tremendously here
