fround command pic 24fFV
Roy
Flowcode V4 User
Post by Roy »
Sir I am trying to use the fround command to limit a floating variable to 2 decimal places. It appears not to work in the simulation.
EMA_APHIA = 0.90
EMA_APHIA = fround (EMA_APHIA,2)
when I run the simulation I get 0.899999976------------lots more.
Does this command work in the simulation or only once complied?
While my program is not yet complete as I test each part as I go I have attached the flowcode file MAP_4CH_24FV_master_slave.fcfx
I have read the articles on the forum that tend to indicate the command does not work on 16bit PIC chips.
Can someone please enlighten me as to what I am doing wrong.
(35.67 KiB) Downloaded 216 times
Roy
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: fround command pic 24fFV
Post by mnf »
One way to do this is to multiply the value by 100 (for 2 decimal places) and assign to an integer...
Note that not all numbers can be represented exactly by fp variables.
Can I also suggest an upgrade to v10 it's free and v4 is now very old
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Please keep in mind computers work in ones and zeros, not floating point numbers. As a result some floating point numbers can not be represented exactly and are a close approximation. Check https://floating-point-gui.de/ for an easy explanation or https://ece.uwaterloo.ca/~dwharder/Num ... /paper.pdf for the heavy theory.
― C.S. Lewis
Roy
Flowcode V4 User
Post by Roy »
Thanks for your comments . I am using version V8.
I would like to use the value in an EMA calculation (1-alhpia) as part of a filter.
It seems to work in my 8 bit version of the program.
Roy
kersing
Post by kersing »
Calculations with the numbers should be fine, it is just displaying for us humans that doesn’t work as expected.
― C.S. Lewis
