Ben,
I am using the Formula Flowcode with Flowcode. I have been successful accessing the LEDs on Port D and driving the buggy forward using PWM. I also had the speaker beeping.
However, at times, I am getting an error when attempting to Compile to Chip. The error is:
Error: Access Violation at 0x7C1084B (tried to write to 0x00030FFC), program terminated.
Then, for no reason the error will go away. And then for no reason return. I know that sounds strange but can you shead any light on what I might be missing?
Thanks,
Jack
Flowcode error
Do you have a dual core processor.
If so this topic may help solve your problem.
http://www.matrixmultimedia.com/mmforum ... php?t=1425
Ben,
Thanks for the information. I installed the fix from Microsoft (http://support.microsoft.com/?id=896256) but it had no effect.
However the fix from Passmark(http://www.passmark.com/forum/showpost. ... stcount=15) solved the problem. No more errors.
Thanks for the help.
Is there any way to get diagrams of the circuits that come in the User guide?
Thanks again.
Jack
Thanks again.
Jack
The diagrams are available in the Formula Flowcode section of the website marked as user guide.
http://www.matrixmultimedia.com/Formflow.php
It is being created as we speak. I will post it up onto the Formula Flowcode section as soon as it is ready.
steamydave
