initialization for 16f88
saravana_3
Post by saravana_3 »
:D Hi friends, i am a beginer for the embedded field, I am previousily using the 16f84, now I have to use the 16f88, at the time of initialization I set as __CONFIG _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_ON & _PWRTE_ON & _WDT_OFF & _INTRC_IO
ERRORLEVEL -302
after compiling the error shows Error[108] C:\KUMAR\PIC\MICSTA~1.ASM 12 : Illegal character (,)
but if use the same programme with the MPLAB it is able to compile, is any one know when I am using the ASM-IDE how to define.
saran
If you are using our hardware then the config line can be left out of your program and PPP can be used to configure the chip.
