Hi Guys!
I have noticed that in flowcode v3, if i select power macro for formula flowcode, it shows me parameter "Power". Which i suppose means we can change this power parameter to different settings to increase or decrease the speed. now my question is how do i assign parameters to each macro? Because in formula flowcode case, when i got the package, these parameters were already assigned to different macros. may be it can be done using component macro. As i have only limited version of flowcode 3 which we get with formula flowcode, so i think this might not be possible for me to implement. if thats the case can i do this on flowcode v2 because i have full version of flowcode v2. But again it doesn't have component macro. any alternatives?
Kind Regards,
elecrobot
How to set parameters in flowcode v2
Re: How to set parameters in flowcode v2
To add parameters to your software macros simply select the macro and then click on Macro -> Edit details. Similarily you can create the parameters when creating a new macro. I have attached a simple example.
- Software_Macro.fcf
- (3 KiB) Downloaded 340 times
