how to read the input ports
saravana_3
Post by saravana_3 »
Hi all
I am using the 16f877a, I set the port A as the input and PortB as the output,
in "c" 'how to scan when any of the portA buttons are pressed
please give some Idea, I want to control the PortB by the portA
thanks
Saran
saran
Re: how to read the input ports
hello Saran
Essentially you can just read porta into a variable by doing the following.
char input;
input = porta;
Then you can create a loop like this to detect when porta changes its value.
char oldinput;
oldinput = input
while (oldinput == input)
    input = porta;
Testing a single bit or switch can can be done as follows.
if (test_bit(porta, 0))
//RA0 Set
else
//RA0 Clear
