error to Hex
Forum for problems or queries regarding the Flowcode application and compiler usage.
tibor
error to Hex
Post by tibor »
hello
I donΒ΄t know ,what I doing bad ,but when I want compile to chip /tutorial and own flow/ ,the program write me :
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F88 "kompas1.c"
BoostC Optimizing C Compiler Version 6.70 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2007 Pavel Baranov
Copyright(C) 2004-2007 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
kompas1.c
Starting preprocessor: "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\pp.exe" D:\rapid-soft\kompas1.c -i "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\include" -d _PIC16F88 -la -c2 -o kompas1.pp -v -d _BOOSTC -d _PIC16
D:\rapid-soft\kompas1.c(468): error: failure
failure
Return code = 1
or example :
C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F88 "TUT_06.c"
TUT_06.c
Starting preprocessor: "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\pp.exe" "C:\Program Files\Matrix Multimedia\Flowcode V3\Examples\TUT_06.c" -i "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\include" -d _PIC16F88 -la -c2 -o TUT_06.pp -v -d _BOOSTC -d _PIC16
C:\Program Files\Matrix Multimedia\Flowcode V3\Examples\TUT_06.c(105): error: failure
failure
Return code = 1
Re: error to Hex
Please post your FCF and C files and we'll have a look.
tibor
Re: error to Hex
Post by tibor »
Hello Steve
Thank you for your interest
kompas.fcf
(13.5 KiB) Downloaded 395 times
kompas.c
(8.78 KiB) Downloaded 409 times
Thank you for your help
Best regards
Tibor
Re: error to Hex
Hi Tibor,
I've had a look and I can compile your program (with Flowcode set to English or Slovak) without problem.
However, I can see where your program is failing. Here's an extract from the C file generated by you:
	//Oneskorenie
	//Delay: 50 ms
	delay_ms(50);
	//Vola
	//Retazce - Svetove strany
	//String Manipulation:
And here's how it is generated on my system:
	//Oneskorenie
	//Delay: 50 ms
	delay_ms(50);
	//Volat Komponentu Makra
	//Call Component Macro: LCDDisplay(0)::Start
	FCD_LCDDisplay0_Start();
The problem seems to be the comment "//VolaΕ¥ Komponentu Makra" which on my system gets converted to "//Volat Komponentu Makra" (specifically, the Ε¥ character).
This may happen on your system because the operating system is set to use a Slovak charset. This is difficult to test here.
For now, you may be able to manually alter these comments (i.e. the Display Name of the icon) manually within Flowcode.
I will look into this to see if there is a better solution.
Re: error to Hex
Tibor,
Can you please check to see if you have the latest Flowcode files:
Flowcode.exe = v3.4.7.48, 24th April 2008, 14:50:40
FlowENGB.dll = v3.4.7.48, 7th April 2008, 09:42:14
FlowSK.dll = v3.4.7.48, 7th April 2008, 09:42:27
