I am doing a project, which is Microprocessor-based CAN-LIN Interface (Gateway).
The project involves programming a microcontroller to create a Bi-Directional Interface between the CAN and LIN bus standards. A test rig will be produced to show how signals originating in one standard are received correctly in the other standard.
I am looking for the hardware and software will be required. I know the E-block LIN BUS solution and E-block CAN training solution is the best and easy solution to deal with this project. But they are expensive to me. Can anyone suggest what is the best solution to achieve this project by E-block?
I want to utilize the E-block to do this project. My main target is to build the CAN-LIN Interface, no running the CAN network and LIN network. Of course, it is better to use E-block to build CAN network and LIN network.
Has anynoe any experiences with this?
Regard Kenny
