Zigbee
Manu
Zigbee
Post by Manu »
When I try to test the Zigbee component, I have failures like :
"D:\Manu\xbee\Emetteur2.c(454:4): error: unknown identifier 'MX_ZIG_TRIS'
D:\Manu\xbee\Emetteur2.c(454:4): error: invalid operand 'MX_ZIG_TRIS'
D:\Manu\xbee\Emetteur2.c(454:17): error: failed to generate expression"...
What's the problem... and the solution?
Thanks for your attention
Manu
Re: Zigbee
Have you defined the component connections. The component will fail if it is not assigned to a port.
Manu
Re: Zigbee
Post by Manu »
OK, the problem is simply that if you don't use a component macro (InitNetwork), it failed!... Sorry.
Someone could give me an example for End device an Coordinator?
Thank you
Manu
Re: Zigbee
Hello Manu
I have a few example files for the Zigbee boards if you need them.
vim
Re: Zigbee
Post by vim »
Hi, i dont want to be a thread stealer however...
I am trying to build a wireless sensor using the zigbee e-blocks. I would appreciate seeing these example files you have. Is there any way you can post them?
Re: Zigbee
Hello Wim
Here you go.
Zigbee_Exercises.zip
(144.66 KiB) Downloaded 437 times
vim
Re: Zigbee
Post by vim »
VIM! not wim!
Is there some kind of explanation to go with these examples?
Also when I try to load them into flowcode 3.2.0.36 there is an error:
The file you are loading was made by a neweer version of flowcode (20 > 19) and may not load correctly.
Followed by:
Flowcode could not load one of the components in the file because it is not recognised on this machine. Install the necessary component before opening this file.
I thought i had the latest version? how do i find out which component i am missing? Is there a log file? Is there another program i must install?
UPDATE:
I think i understand, i have to update my version to v3.4.7.48 in order to take advantage of the zigbee modules that i have.
