Flowcode for AVR no examples?
Forum for suggestions regarding the next update / release of Flowcode
Eumel
Post by Eumel »
just downloaded the AVR version. I cannot find a single example after installing the demo version. Is the AVR version really working? As far as I can see there are only PIC examples for downloading from the webside.
Without samples it's difficult to see if the program is of any use.
Greetings from Germany
Eumel :cry:
Sean
Has thanked: 6 times
Been thanked: 44 times
Re: Flowcode for AVR no examples?
Post by Sean »
All versions of Flowcode have an 'Import' facilily in the File menu. This allows files created in one Flowcode version to be used by all the others another. The default version for most example programs is still PIC, but most programs can be imported into any version without modification.
With some of the more advanced examples it might be necessary to re-assign some of the I/O to avoid conflicts - depending of the target device being used.
You can download the PIC versions of the examples and import them into Flowcode for AVR. When you save them they will be given the '.fcv_avr' extension.
Look inside your Flowcode_AVR folder. Normally C:/Program Files/Matrix Multimedia/Flowcode_AVR. You will find a folder named examples containing 34 example files.
