Free memory
rapid
Free memory
Post by rapid »
how can I see how much memory (RAM, FLASH) are still free after compiling?
jmccorison
Re: Free memory
Post by jmccorison »
Do a build to hex or to the chip and at the bottom of the listing displayed on the screen it will show memory used, both in number and percent, with the amount free, based upon the chip, also listed.
rapid
Re: Free memory
Post by rapid »
no I canΒ΄t see it.
I think something am adjusted or the demo version doesnΒ΄t show that. :roll:
Compilation successful!
Return code = 0
C:\Programme\Matrix Multimedia\Flowcode_AVR\Tools\MX_bats\avrb.bat "C:\PROGRA~1\MATRIX~1\FLOWCO~2\Examples\Flowcode11.elf" "C:\PROGRA~1\MATRIX~1\FLOWCO~2\Examples\Flowcode11.hex"
C:\Programme\Matrix Multimedia\Flowcode V3\Examples>"C:\PROGRA~1\MATRIX~1\FLOWCO~1\Tools\MX_bats\..\bin\avr-objcopy" -O ihex -R .eeprom "C:\PROGRA~1\MATRIX~1\FLOWCO~2\Examples\Flowcode11.elf" "C:\PROGRA~1\MATRIX~1\FLOWCO~2\Examples\Flowcode11.hex"
HEX file creation successful!
Return code = 0
FINISHED
.............____________
Re: Free memory
The AVR version of Flowcode does not create this data by default. But there is probably a way to do it by using some command-line switches when compiling/linking the code.
rapid
Re: Free memory
Post by rapid »
Hi Steve,
I think you are right, but I did not find the switch inside GCC.
Can you help me?
Sean
Has thanked: 6 times
Been thanked: 44 times
Re: Free memory
Post by Sean »
I have found a way to obtain some meaningful memory useage information from GCC.
Unzip the attached avr-size.exe file into the Tools\bin folder of your Flowcode_AVR installation.
avr-size.zip
(174.28 KiB) Downloaded 417 times
Copy the following line into the avra.bat file in the 'Tools\MX_bats' folder of your Flowcode_AVR installation.
"%~dp0..\bin\avr-size.exe" -B -d %2
Place it above the first line containing '@ECHO.'. You can replace the -d switch with -x to have the segment data displayed in hex rather than decimal notation. The total useage is displayed in both dec and hex format regardless of the selected segment display format.
