Bluetooth Board Connection
jcooper
Post by jcooper »
I've got a Bluetooth board, and was hoping to connect it to the UWTerminal application supplied by EZURiO. Is there a SOP in place for connecting the Bluetooth board directly to a computer's serial port? From your schematics, it looks like the current level shifter may not be adequate for a direct connection.
No trees were harmed in the posting of this message. However, a large number of electrons were terribly inconvenienced.
Re: Bluetooth Board Connection
Im afraid that the Bluetooth board does not currently support this. However if you wanted you could rig up the RS232 board to forward the signals to and from the bluetooth board. Not sure if the 4 signals (TX, RX, CTS, RTS) would be enough for the UWTerminal software though.
jcooper
Post by jcooper »
What is the part number for the EZURiO module that you are using on the Bluetooth Board? Do you have schematics for it?
Here is the Bluetooth module.
BLU2i V2 Bluetooth module BLU2i Bluetooth Module Spectre
And here is the Hirose connector
Bluetooth connector (DF12) DF12-3.5-40DP-0.5V-80 2001 ICE
Do you mean a schematic for the bluetooth board or the bluetooth module? If you need the bluetooth board schematic then it can be found in the E-Block datasheets area of our website.
jcooper
Post by jcooper »
I need information on the Bluetooth module itself - I already have the board's schematics. Since I'm doing my development in C rather than using Flowcode, I need a more intimate knowledge of how each piece works. Can you tell me if this is the correct datasheet for the Bluetooth Module?
http://www.ezurio.com/files/00547.pdf
Yes - that is the correct module.
The "AT command reference" manual will also be useful to you. You should be able to find this on the Ezurio site.
jadiflow
Flowcode v5 User
Has thanked: 19 times
Been thanked: 16 times
Post by jadiflow »
Steve,
I assume that this Bluetooth board supports the SPP - Serial Port Protocol?
Meaning that it can be used to build up a link to a PC Bluetooth virtual serial port?
Jan Didden
From the manual, the following Bluetooth profiles are supported:
FTP Server, SPP, DUN, FTP, Audio Gateway, Headset, Handsfree
Our Bluetooth course does include some examples where the module is connected to a PC via a virtual COM port. This course should be downloadable from our website somewhere.
