Problem in fault finding
Kumaran
Post by Kumaran »
I have developed a program for PIC16f877 in flowcode. after compiling I have dowloaded the program using MPLAB IDE. ything went sucessfully. However there is no reaction in the IC. Means it is not doing anything whatever I program. What could be the reason? Is their any other compiler can be used for downloading the program using MPLAB ICD2? Is their any way to do online debugging?
Kumaran
Kumaran
Re: Problem in fault finding
Post by Kumaran »
Why this post has not been aswered? While my ohter posts are answered on same day.
Kumaran
It could be a configuration word problem. Make sure you are using configuration data that is appropriate to your hardware (e.g. clock settings). Also, turn the watchdog timer off if you are not using it.
If you are still having problems, try creating a simple LED-flasher program and get this to run before trying to solve the problem on a more complicated program.
