when debugging i found a need to do a search for certain variables in my flowcode program and found it time consuming to try and find all instances of the variable in question, Can there be a facility to have a "find" in the menu bar to search sequentially through the program for the variable.
And on a similar note. view the chosen variable_ item progressing through the program (while running in debug mode) .....maybe a colour change of the flowcode icon as the variable is used passing through it. This would allow oneself to see the program branching or not as the case maybe. This is in addition to the `program icon high lighter` that is available now, which shows how the flow of the program progresses. But my addition would show various variables if they were hit.
