Sending data to LCD using PIC
tazogu
Post by tazogu »
I am trying to write a programme in PIC to create a display. I have looked through the Datasheet of the LCD but it only helps to initiate the LCD but as far as changing the position of the cursor or sending an ASCII code to be displayed on the LCD not much of a help. I would like to look at a sample code that not only initiate the LCD but also sends data that can be seen on the LCD.
achillis1
Has thanked: 91 times
Been thanked: 8 times
Re: Sending data to LCD using PIC
Post by achillis1 »
hi!
Are you going to write yourself the code or do you use the flowcode3 graphical interface?
Google "PIC Alphanumeric LCD Source Code" and you should get lots of hits showing exactly how to create your code. For an assembler version of the driver code try searching for "LCDTERM"
