temperature sensor
achillis1
Has thanked: 91 times
Been thanked: 8 times
temperature sensor
Post by achillis1 »
hi!
I want to ask if I want to measure temperature and display it on an LCD screen do I have to get the sensor board and the temperature probe?
Thank you.
Re: temperature sensor
If you are using a EB006 or an ECIO then yes you will need a sensor board to interface to our temperature sensor. If you have the HP488 Dev Board then you can interface directly with the sensor without the need of the sensor board.
