LCD macro Cursor doesn't work with variables
Forum for problems or queries regarding the Flowcode application and compiler usage.
bigparmezan
Post by bigparmezan »
if I try to use the LCD macro Cursor using variables, say
x=0
y=0
Cursor (x,y)
it doesn't work.
It works fine in the simulation but not on the actual HW.
It works with literals, of course:
Cursor (0,0)
It must be a compilation bug! My version of Flowcode is 3.4.7.48.
I'm attaching the fcf file. Thanks for help.
Flowcode_Cursor.fcf
(4 KiB) Downloaded 356 times
Dan81
Been thanked: 60 times
Re: LCD macro Cursor doesn't work with variables
Post by Dan81 »
Did you test the programme on HW with cursor(0,0) ?
I think your configuration is not good.
Click on : chip / configure / Switch ...
The config word is 0x3FFF, it should be 0x3F7A :
- oscillator : HS (not RC)
- Watchdog Timer: Off
- Low voltage Prog : Disable
I hope this can help you
Daniel
