c for arm on WindowsXP-64 and registercode
joe
Post by joe »
When instal C4ARM and running then received a message: Key is not correct.
so what?
Joe
Re: c for arm on WindowsXP-64 and registercode
Hello Joe
Atmel has so far not released a driver for the 64-bit operating systems, Is there another non 64-bit machine you can install and use the software with. The course itself should run ok though. You can email me with your serial code if you like and I will test it here on a 32-bit and a 64-bit machine.
