EICO RC1 & RC2 stuck together?
Forum for problems or queries regarding the Flowcode application and compiler usage.
jadiflow
Flowcode v5 User
Has thanked: 19 times
Been thanked: 16 times
Post by jadiflow »
I have a funny issue. I'm bitbanging some peripheral on RC1 and RC2 of an EICO 2455 module.
When I step through my program, I notice that whenever I set RC1, RC2 also is set, and vice versa. It looks as if RC1 and RC2 are connected together.
As target I use EICO-28 as modified for the erroneous RA6 that we found some time ago. I can't see anything wrong with the .fcd at first glance.
What do you think?
Jan Didden
Re: EICO RC1 & RC2 stuck together?
Hello Jan
Are you noticing this problem on the ECIO hardware or in the simulation in Flowcode.
Could be that the pins have been physically shorted together somehow. We do a test when manufacturing the ECIOs to make sure that no pins are shorted together so it maybe that this has happened recently or maybe the short is very tempremental.
Can you check the pins of the Microcontroller onboard the ECIO. Seeing as its the ECIO28 it should be fairly easy to spot if there is a short anywhere on the board.
jadiflow
Flowcode v5 User
Post by jadiflow »
No I'm seeing it on the sim.
Jan Didden
Hello Jan
Ok sorry about that. Ive fixed the FCD file and it should now be working correctly.
ECIO-28.fcd
(8.53 KiB) Downloaded 486 times
jadiflow
Flowcode v5 User
Post by jadiflow »
OK thanks, fixed.
Jan Didden
