9 pin D connector pins
Can someone tell me for example which bit on port A corresponds to what pin on the port A 9 pin D connector?? Id like to build my own "e-blocks" for various projects. Are all bit "0" on the same pin on all ports for example? This is for the EB006 programmer board btw. THANKS!!
Sean
- Has thanked: 6 times
- Been thanked: 44 times
Re: 9 pin D connector pins
All E-blocks port connectors have the same pin configuration:
Port pin -> D9 pin
0 1
1 2
2 3
3 4
4 5
5 6
6 7
7 8
0V is always connected to pin 9 of the D9 connector.
Port pin -> D9 pin
0 1
1 2
2 3
3 4
4 5
5 6
6 7
7 8
