Hello, I was wondering the pinout for the db 9 connectors on the E-blocks PICmicro USB Multiprogrammer are. Im planning on using it to control a project of mine and need to know the pinout. Is pin 9 +volts? and pin 1 ground? if so which pins correspond to which bits in ports A, B, C, D ? any help will be appreciated, thank you.
Nickolas
Eblocks DB9 connectors
Sean
- Has thanked: 6 times
- Been thanked: 44 times
Re: Eblocks DB9 connectors
All E-blocks port connectors have the same pin configuration:
Port pin -> D9 pin
0 ----------> 1
1 ----------> 2
2 ----------> 3
3 ----------> 4
4 ----------> 5
5 ---------->6
6 ---------->7
7 ---------->8
0V is always connected to pin 9 of the D9 connector.
Port pin -> D9 pin
0 ----------> 1
1 ----------> 2
2 ----------> 3
3 ----------> 4
4 ----------> 5
5 ---------->6
6 ---------->7
7 ---------->8
scnickolas
The information you are looking for can be found in the E-Blocks users guide available from here.
http://www.matrixmultimedia.com/eblocks/index.php
To confirm pin 9 is ground.
KeithSloan
- Been thanked: 1 time
Out of interest why did Matrix Multimedia not make Pin 9 Vcc and the shell Gnd. Would have saved running all those 5V wires to those E-Block that need a supply.
Sean
The GND connection is required on all E-Blocks boards as a signal reference. A positive supply is required for most boards, but is not always 5V. Wiring the positive supply separately allows the appropriate voltage to be connected.
Also the outer shell is not always connected across eg when using IDC cables.
