Could some kind person show me how in flowcode how to change the states in the outputs. By this I mean the following, I have the following when I have two outputs which are active High on the next remote clock pulse I wish the two outputs to go Low. As the input clock has a variable duration in times it would require the input to ignore the duration until a state change has occured on the output. I can set it up to read the input but I am getting stuck is how to ignore the input until a state change.
The flow chart should go something like this ( Input clock detected - Read input pin - Make two outputs High and ignore any duration of clock width until next clock pluse - next clock pluse detected - make same two outputs Low and repeat flow chart. )
My issue is I am getting stuck at (Make two outputs High and ignore any duration of clock width until next clock pluse) I can set up the read value on input and make a output change state but the ignore until next pluse is causing the problem
I hope I have explained myself well enough for someone to assist as flowcode is still somewhat new.
Flowcode question
- Dan81
- Been thanked: 60 times
Re: Flowcode question
Hello jim
Try one of these Flowcharts.
For "Scrutation", you can use any Port ( A , B , ..).
But for "interruption" , you must use RB0 as input.
Or use RB Port change interrupt and the inputs will be RB4 ou RB5 or RB6 or RB7.
Daniel
Daniel
- change-state-interruption.fcf
- (5.5 KiB) Downloaded 397 times
- change-state-scrutation.fcf
- (5 KiB) Downloaded 365 times
Thanks I will give that a go looks like what I was attempting to do, I have other stuff to go on but at least it has moved it forward a bit.
Works ok I see the bit were I got stuck now am just changing a few things around but looks good. Thanks for you help as they say a small snip of codes says a thousand words.
