MX015 - Basic USB Communications for PIC
Article: https://www.flowcode.co.uk/old_site/resources/get ... php?id=379
If you have any questions for the author or comments on the article, please post them below.
randomrichard
- Has thanked: 21 times
- Been thanked: 7 times
Re: USB Comms using EB006 / HP488 Programmer Boards
Thanks for the tips on configuring the 18F4550. I now have no problem with sending or receiving bytes using its USB serial port. However, I can't get past a difficulty with your 'USB serial string demo.fcf' example. In the Flowcode4 example I downloaded the "Read String from USB" macro properties has '100,test, 64' in the Parameters box and 'x' in the Return value: (STRING) box. Now that's three parameters and a byte value so if I press OK F4 says there is an error, not surprisingly. I tried replacing those entries with '100, 64', and 'test', but that didn't work either although it compiled OK. Help , please.
I have looked at the example and fixed it so it will work correctly with the current version of the component.
- USB Serial String Demo.fcf
- (8.5 KiB) Downloaded 1356 times
randomrichard
Ben
Thanks for your help. It works fine now and I should be able to work out why. Now for the two-way comms...
Richard
Richard
Re: MX015 - Basic USB Communications for PIC
jose
- Flowcode V4 User
- Has thanked: 7 times
- Been thanked: 10 times
Hello Ben,
I see now, thanks.
I'm having trouble communicating with the pc: detects but does not recognize the USB device (?)
I could not find the article "communicating with the PC" referred to in MX015.pdf, to have some help about hyper terminal and USB
I see now, thanks.
jose
- Flowcode V4 User
Ben,
Will it be possible for you to give a small exemple of reading a key from a PC USB keyboard into a variable?
It will be a great help
Hello Jose,
Does the device appear in the device manager as an unknown device or does it go into the HID section as a HID device?
If your getting the unknown device problem then its likely that either your configuration or clock speed is off. Could you post up your program and I will have a look for you.
Regarding reading a key from the keyboard into a variable, would this be on the PC? You mention hyperterminal, do you instead want a serial keyboard rather then a HID keyboard?
Communicating with a PC article is available here.
http://www.matrixmultimedia.com/mmforum ... =26&t=4793
jose
- Flowcode V4 User
Hello Ben,
I was using a 4 MHz crystal, then i change it to 24MHz and it is working (some times not)
the file i'm using is your Ex2.keyboard. i will try others configuration speeds.
The example I need is to connect a real USB keyboard to the chip and read hex or decimal key value to a variable and then display it on a LCD or something else
jose
jose
Hello Jose,
Im afraid connecting a USB device such as a keyboard to a chip is not possible as USB host hardware is required. Devices supporting the USBotg peripheral should allow this but the Flowcode components do not currently support USBotg so you may have to refer to one of the Microchip examples. I have a Flowcode example program for reading a PS2 style keyboard if this is any good to you.
jose
- Flowcode V4 User
Hi Ben,
Ok i will try with Microchip examples.
I guess you mean PS2_key and PS2_key2 files, i have those but they gives this error:
" Error: Unresolved external function:'sendByte(unsigned char)". The strange thing is that i remove all references to "sendByte and error remains.
If you solved this or have any other file, yes please..
Thank you
Thank you
Here are the most recent source files I have for the PS2 keyboard. The C file has to be in the same directory as the Flowcode project file to work correctly.
- PS2_Keyboard.c
- (5.29 KiB) Downloaded 1050 times
- PS2_Key2.fcf
- (5.5 KiB) Downloaded 1124 times
Just had a quick compile and gotten the same sendByte error message. I will have a look through and see if I can dig out this function.
jose
- Flowcode V4 User
Hi Ben,
I finished this litlle ps2 keyboard program
http://www.matrixmultimedia.com/mmforum ... =26&t=8870
jose
jose
Hi Jose,
Looks great many thanks for sharing
