hi,
I'm using Flowcode V3 but I have a problem...
I' must to change a delay time in ms fox example 1,1ms 1,2ms ecc. but I don't know how...
can someone help me?
thanks!
SET DELAY
Sean
- Has thanked: 6 times
- Been thanked: 44 times
Re: SET DELAY
Flowcode can not currently provide direct control of delays below 1ms. However, there is access to a function called 'delay_10us' via Flowcode C code blocks.
You could make a 1.1ms delay directly with the following C code:
delay_10us(110);
A Flowcode variable can be passed to the C function if program control is required:
An example Flowcode variable - Delay1- can be referenced in C code using the name FCV_DELAY1.
delay_10us(FCV_DELAY1);
Flowcode delay blocks and C code block delays can be used sequentially to provide a range of delay options.
delay_10us(110);
Re: SET DELAY
I'm new to Flowcode. Is there a list of all the C functions we can implement with the syntaxes ? I'm very impressed with what I have been able to do so far BUT I know it has the possibility to do more.
J
J
Re: SET DELAY
There is a manual for the BoostC compiler located inside the Flowcode V3/BoostC directory.
Sean
Re: SET DELAY
There is a complete manual for the C compiler used by Flowcode in the boostc folder of your Flowcode installation (boostc.pdf). You can access all the C functions, device specific registers, etc. using the Flowcode C Code blocks (and the target device data sheet).
Any variables that are to be passed between Flowcode and C must be declared in Flowcode. They will then be available to the C code with the name in upper-case characters, preceeded by FCV_ for global variables and FCL_ for local variables, FCL_ for local variables (declared within Flowcode macros) and FCR_ for macro return variables.
Example:
The Flowcode global variable, Var1, could be accessed by C Code as FCV_VAR1.
Variables used purely within the C code can use the normal C naming conventions.
Note:
C code can not be simulated and is not error-checked by Flowcode. The code is passed directly to the C compiler.
The Custom Code components can be used to write complete new components in C, and allow property values to be transfered to each instance used by Flowcode.
Example:
Note:
