How to use 7 seg Display?!? FlowCode3 PRO Version
Forum for problems or queries regarding other Flowcode Components. Eg LEDs, Switches, LCD, Gfx LCD etc
rcosta
Post by rcosta »
Hi Mr.
I`d like to know if someone can give me a BIG Help about how can I use in FlowCode3 a 7 segment display as CATHODE COMMON?
Its because I have to work with the display 7 seg (Cathode Common) and not the ANODE COMMON that exist in FlowCode.
I`ve heard that I`ll need to change something in the C Code, but it is my question and I could really appreciate the help of someone on this subject, as example:
- Which C Code File do I need to change? Which line?
- What do I need to re-write to be allowed to work with CATHODE COMMON display?
PLEASE, IF some good person know how to do that, help-me please, is just what I ask!
P.S1.: I ask sorry about my English, its because I`m a Portuguese speaker from Brazil and this support forum is only in English so I have double difficulties. :(
P.S2.: Where do I get the last updates for my Professional License of FlowCode 3 for PICmicro?
Thanks in advance for any one that can help-me!
Best Regards,
Rodrigo Costa.
rcosta
Re: How to use 7 seg Display?!? FlowCode3 PRO Version
Post by rcosta »
Is this changing in FlowCode 3 too difficult that no one know how to do it work with a 7 Seg Cathode Common display?! Including a Matrix Support Team? :shock:
I`m really impressed!
16 views in this post and no answers! Howww it is outstanding for a Forum board specific for this! :oops:
The C code files for the components are in the "components" folder of Flowcode. I believe I explained to you on Friday via email that Flowcode only supports a common-cathode 7seg display and if you needed to create a common-anode version, you would need to write your own C code and were essentially on your own.
And sorry that you have not received a reply until now. I have been busy with my children over the weekend and could not find the time to answer you until now.
rcosta
Post by rcosta »
Dear Steve,
Thank you very much for your Reply!
So, I did understand you with the mail...but I do not have knowledge to write a C routine changing from the actual ANODE common to CATHODE common! :cry:
So, I just ask if you or someone could give to me the necessary C routine to use as Cathode common...or is it ask so much :?:
Does not have any problem if Matrix cannot support this routine...I`m responsable for the changing.
And, I bought FlowCode because I do not know to program by some PIC language so I cannot change or build a C routine alone.
Thank you for your attencion.
Rodrigo Costa.
goldwingers
Post by goldwingers »
I would suggest you check out the Matrix multimedia web site and look under the Eblocks hardware for EB008-30-1 and download the PDF file, this shows a 4 segment common Anode schematic.
To change this to a common cathode use a transistor to switch cathode via port A and feed the anodes from port B. Simple electronic switching
I have added a simple PDF to show how I do the change
Ian
common cathode.pdf
(16.08 KiB) Downloaded 502 times
