USBSlave rename Start_Slave_Service
Forum for suggestions regarding the next update / release of Flowcode
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Suggestion to rename the Start_Slave_Service of the USBSlave component to Run_Slave_Service or something along those lines.
Start suggests (at least to me) a function spending a finite amount of time within the function. Looking at the code of Start_Slave_Service it becomes obvious it will not return until Stop_Slave_Service is called.
Best regards,
Jac
― C.S. Lewis
Re: USBSlave rename Start_Slave_Service
Hello Jac
A good suggestion, you are correct the function does not return unless then stop_slace_service macro is called.
I will find out how difficult it will be to allow for this macro name change to work with code imports from previous versions. If it's an easy task then I'll put your suggested change into V4.
