question regarding use of variables
IAB48
Post by IAB48 »
I'm writing a programme in flowcode that uses a keypad to determine what particular folder of music plays. The music is stored in various folders on a usb stick and the usb stick is plugged into a vmuisc2 module, whic in turn is connected to the pic microcontroller
Example
If keypad 1 is pressed then the following sequence occurs
vmusic 2 is stopped
folder change to CD\
folder is then changed to reflect the keypad button pressed - in this case it would be folder1
vmuic2 is started to repeat all mp3 tracks in folder1.
so this would be
VST (cr)
cd\ (cr)
cd folderx (cr) where x reflects the keypad button pushed
VPR (cr)
As I want to have upto 20 folders I'm looking at ways to shorten the number of decisions
At present I have a macro that says is myvariable (which is the return of getkeypad) = 1 - no; then go to next decision
is myvariable = 2 no; then go to next decision
This would require 20 decisions potentially one for each button in a 4 x 5 keypad
The only line that is different in each decision branch is the CD folderx line where x could be anything from 1 through to 20
I was wondring what could be done to reduce the number of the decisions
I've tried storing the keypad into eeprom and recalling it later as a variable to send to RS232 port but without success. At best I can get the RS232 send to change to a * which is basically saying it is a non printable character.
I guess my thought is to recall the keypad number selected so I can set it direct to RS232
Example
keypad value stored (somewhare as a variable)
component macros to send RS232
VST (cr)
cd/ (cr)
Cd folder
recall keypad variable
(cr)
VPR (cr)
The intent being to insert the keypad value directly after folder ( with no spaces) rather then have a decision for each possible value.
Any thoughts please
Ian Burrows
Re: question regarding use of variables
Hello Ian
It sounds like the problem you are haing is due to the subtle differences between decimal numbers and ASCII numbers. Incoming RS232 data is in the form of ASCII and this is probably why you are seeing the * characters during simulation.
There is more information regarding this available here.
http://www.matrixmultimedia.com/mmforum ... =26&t=4792
rustyroadie
Post by rustyroadie »
Hi Ian,
Have you managed to come right with the Vmusic? Would it be possible for you to share your code?
Cheers,
Rusty
