How would i go about designing a macro to simulate a 4 x 4 keypad.
I'm guessing that you make the equivalet of 1 column high and then read each row and repeat for each column, but where do you go from there?
Any suggestions or Links that I could learn more from would be appreciated.
Ian B
Multiple LEDS - how to
Re: Multiple LEDS - how to
Simulation of a 4 x 4 keypad will be included in V4 of Flowcode.
For now though I would just assign a variable with the keypad press you require to do the simulation.
Alternativly you could mock up the hardware and use this as your test bed. This way there are no suprises when you come to designing your hardware.
