Every time I compile to HEX I get the Flowcode.exe has encountered a problem and needs to close etc.
All my other Flowcode files compile 100% OK
Any ideas on the constant program crash please?
Flowcode only crashes with attached file
- PMW to AC2.fcf
- (5 KiB) Downloaded 421 times
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Flowcode only crashes with attached file
This is a strange one. It looks like the "Enable PORTB Change" icon in the main flowchart has gone wrong. It should work again if you edit the properties of the interrupt (right-click the icon and select properties, and then click the properties button in that window) and then resave the file.
