AVRISP mkII not able to be installed
For users of Matrix Multimedia Electronics software to discuss projects, circuits and any other electronics concepts.
ivan85
Post by ivan85 »
Hello there,
I'm wondering someone can help me out. I have a problem trying to install the driver for AVRISP mkII, for the AVR programming board EB019-00-2 Atmel AVR Board.
I've just bought the 'AVR C Programming pack' today and after installing
E:\software\ARM Programmer\Install\mLoader_Setup which is suposed to install the AVRISP mkII driver from the file mx_eb031.inf , before plugging the board, there's still a yellow question mark on the device manager for this device, meaning the PC still hasn't recognised the device.
Is there a solution?
Also, it is after mLoader_Setup is ran, and the device plugged in, that the ARMBoardDriverInstaller.exe should then be run? ( I just followed what it says in the readme)
Thanks!
Ivan
Re: AVRISP mkII not able to be installed
Hello Ivan
There is an updated driver for the AVRISP mkII programmer available from here.
http://www.matrixmultimedia.com/mmforum ... .php?id=97
Hopefully this will remove the question mark next to the device for you.
