PICkit programmer
saschech@gmx.de
- Has thanked: 1 time
- Been thanked: 26 times
PICkit programmer
Hallo Steve
In the moment i program my pic`s with a MPLABΒ® ICD 2 kompatibler In-Circuit
Debugger/Programmer .
I show,in the v4 setup "pickit 2 programmer " and i found on the microchip homepage,
a PICkit 3 Debug express programmer complete with a demo board 18F45k20.
To day i become this programmer , but the pic is not in the device list v4.
I copy PiCkit3 folder in the tool folder of v4 and change the compiler-option to the pickit 3 directory,but i become
an error.
V4 is a new software,pickit3 also.I want not buy an old programmer.
Please can jou build a 18F45k20.fcd file? and add in the setup PICkit3 programmer?
Very hopeful for these
Regards Wolfgang
an error.
Regards Wolfgang
Re: PICkit programmer
Hello Wolfgang
I have created the new definitions for the 18F45K20 family of devices. Please extract the archive into your Flowcode V4 folder, restart Flowcode and the new devices should appear. Note that PPP will not currently support these new devices.
- Flowcode4.zip
- (21.54 KiB) Downloaded 470 times
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Hi Wolfgang,
PICkit3 does not seem to have a command-line interface to allow us to use it with Flowcode - it only seems to work with MPLAB. While researching this I found the following on the Microchip forum:
For the moment, the PICkit2 will give you less headache and more features.
Fully agree. I needed a programmer and bought Pickit 3, hoping it would have more features and less headache, because of its higher price and because it was a newer model. It looks that I was wrong.
I've been using simple PICkit 2 programmer tool before and loved it's simple interface and logic / serial tools, but it seems that it just isn't available for PICkit 3 (yet?).
I hope we get more tools for PICkit 3 soon.
saschech@gmx.de
Hallo Steve , Benj
thanks for the files , works pefect in v4.
Are the files also for v3? becouse i become in v3 a error no fcd file...
Regards Wolfgang
Regards Wolfgang
saschech@gmx.de
Hallo Steve
To day i have install the Pickit2.It works with the MPLab.
If i want program with v4,i receive returncode: 32.
Please help.
regards wolfgang
Please help.
regards wolfgang
- Steve
Hello Wolfgang,
I'm sorry, but that is not a valid return code from the PICkit2 programmer application. Here are the expected return codes:
One thing to note is that the firmware in the PICkit2 may need to be upgraded - you could try this first (it needs to be v2.32 or later). Instructions on how to do this are in the "readme" file for the PICkit2.
If you are still having problems, please post the output from Flowcode here - it may help to see what is returning this error message.
// Return Codes
#define OPSUCCESS 0 // operation completed as expected
#define VOLTAGE_ERROR 5 // Vdd or vpp error detected
#define OPFAILURE 7 // operation failed
#define NO_PROGRAMMER 10 // Unable to find a PICkit 2 programmer
#define WRONG_OS 11 // OS firmware must be upgraded
#define FILE_OPEN_ERROR 15 // returned if a file to read to (-gf..) cannot be opened.
#define DEVICEFILE_ERROR 24 // the device file was not found or an error occured while loading.
#define UPDGRADE_ERROR 28 // returned when OS upgrade fails.
#define PGMVFY_ERROR 34 // returned if program or verify operation fails.
#define INVALID_CMDLINE_ARG 36
#define INVALID_HEXFILE 37 // Error reading hex file.If you are still having problems, please post the output from Flowcode here - it may help to see what is returning this error message.
saschech@gmx.de
Hallo Steve
Sorry it is ret.code : 36
File name: D:\sachs_work\ECIO\V4\sa_ecio\sa_ecio.c
Generated by: Flowcode v4.0.0.53
Date: Tuesday, June 30, 2009 17:04:38
Licence: 30-Day Trial
***DEMO VERSION***
NICHT FΓR KOMMERZiELLE ANWENDUNGEN
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic18.flowcode.exe -v -t PIC18F8722 "sa_ecio.c"
Additional Debug info
sShortAppPath: C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\BOOSTC~1.EXE
sAppPath: C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic18.flowcode.exe
sAppFullSwitches: C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\BOOSTC~1.EXE -v -t PIC18F8722 "sa_ecio.c"
sWorkingDir: D:\sachs_work\ECIO\V4\sa_ecio
lengths = 79, 78, 29
Return code = 0
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostlink.pic.exe -ld "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic18.lib flowcode.pic18.lib rand.pic18.lib float.pic18.lib "sa_ecio.obj" -t PIC18F8722 -d "D:\sachs_work\ECIO\V4\sa_ecio" -p "sa_ecio"
sShortAppPath: C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\BOOSTL~1.EXE
sAppPath: C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostlink.pic.exe
sAppFullSwitches: C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\BOOSTL~1.EXE -ld "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic18.lib flowcode.pic18.lib rand.pic18.lib float.pic18.lib "sa_ecio.obj" -t PIC18F8722 -d "D:\sachs_work\ECIO\V4\sa_ecio" -p "sa_ecio"
lengths = 71, 254, 29
Return code = 0
Launching the programmer...
C:\Program Files\Matrix Multimedia\Flowcode V4\tools\PICkit2\pk2cmd.exe -PPIC18F8722 -Fsa_ecio.hex -M -A5 -H -BC:\Program Files\Matrix Multimedia\Flowcode V4\tools\PICkit2\
sShortAppPath: C:\PROGRA~1\MATRIX~1\FLOWCO~1\tools\PICkit2\pk2cmd.exe
sAppPath: C:\Program Files\Matrix Multimedia\Flowcode V4\tools\PICkit2\pk2cmd.exe
sAppFullSwitches: C:\PROGRA~1\MATRIX~1\FLOWCO~1\tools\PICkit2\pk2cmd.exe -PPIC18F8722 -Fsa_ecio.hex -M -A5 -H -BC:\Program Files\Matrix Multimedia\Flowcode V4\tools\PICkit2\
lengths = 71, 155, 29
Return code = 36
Flowcode konnte das Flussdiagramm nicht in den Microcontroller ΓΌbertragen. ΓberprΓΌfen Sie die Optionen der Programmer-Software und die physikalischen Verbindungen.
FINISHED
Regards wolfgang
***DEMO VERSION***
Return code = 0
Return code = 0
Return code = 36
FINISHED
Regards wolfgang
Hello Wolfgang
There is a fix for the PICkit command line detailed here.
http://www.matrixmultimedia.com/support ... .php?t=554
saschech@gmx.de
Hallo Benj
After i do these,the Pickct2 works ok.
One more question over compiler option:
The programmer must have correct links.....but in the c-compiler option i view .....boostc.pic16.flowcode.exe
and my project with a 18F8722,compiling is ok?????????
Flowcode automatically converts between "16" and "18" depending on the target chip. It does not matter whether the options say "16" or "18".Steve Tandy,
Matrix Multimedia Ltd.
For what i have these option ????????
Regards Wolfgang
Regards Wolfgang
Hello Wolfgang
Glad the PICkit is working correctly for you now, thanks for letting me know.
If the compilation is working correctly then you do not have to worry about the compiler and linker settings. These are just there to allow Flowcode to be installed in a folder other then the default folder.
Also yes the 16 / 18 parameter is swapped automatically depending on the target you are using.
Fix works great!Benj wrote:Hello Wolfgang
However Can you please add (in you own words
If you want PICkit to keep target power applied, then -T is required
i.e -BC:\Program Files\Matrix Multimedia\Flowcode V4\Tools\PICkit2\ -PPIC%p -F%F.hex -M -A5 -R -T
saschech@gmx.de
Hallo All
Is there also a way switch on " Preserve device EEPROM " ?
Regards Wolfgang
Regards Wolfgang
Re: PICkit programmer Error 37
If anyone has error 37:
Look at Complier messages at the line which shows
pk2cmd.exe -BC:\Program Files\Matrix Multimedia\Flowcode V4\Tools\PICkit2\File Name
If this file name is not exactly same as file you are compiling then change
-BC:\Program Files\Matrix Multimedia\Flowcode V4\Tools\PICkit2\ -PPIC%p -F%F.hex -M -A5 –R
to
-BC:\Program Files\Matrix Multimedia\Flowcode V4\Tools\PICkit2\ -PPIC%p -F%f.hex -M -A5 –R
Thanks to Steve for solving that and -T option
Benj would it be a good idea to permanently change -F%F to -F%f when any information is posted regarding settings. That is assuming it works on every PC , even those PC where is it not required?
to
saschech@gmx.de
Hallo Benj
I found these but if i put in ........-MPIC......... i become on compiler a error 34
9. Command Line Options
The following commands are available in the command line interface.
PICkit 2 COMMAND LINE HELP
Options Description Default
A<value> Set Vdd Device Specific
C Blank Check Device Do not Blank Check
D<file> OS Download None
E Erase Flash Device Do Not Erase
F<file> Hex File Selection None
G<Type><range/path> Read functions None
Type F: = read into hex file,
path = full file path,
range is not used
Types P,E,I,C: = ouput read of Program,
EEPROM, ID and/or Configuration
Memory to the screen. P and E
must be followed by an address
range in the form of x-y where
x is the start address and y is
the end address both in hex,
path is not used
(Serial EEPROM memory is 'P')
I Display Device ID Do Not Display
K Display Hex File Checksum Do Not Display
M<memory region> Program Device Do Not Program
memory regions:
P = Program memory
E = EEPROM
I = ID memory
C = Configuration memory
If no region is entered, the entire
device will be programmed.
(serial EEPROM memory is 'P')
P<part> Part Selection. Example: PIC16f887 None
U<value> Program OSCCAL memory, where: Do Not Program
<value> is a hexidecimal number
representing the OSCCAL value to be
programmed. This may only be used in
conjunction with a programming
operation.
V<value> Vpp override Device Specific
W Externally power target Power from Pk2
Y<memory region> Verify Device Do Not Verify
P = Program memory
E = EEPROM
I = ID memory
device will be verified.
Z Preserve EEData on Program Do Not Preserve
? Help Screen Not Shown
Each option must be immediately preceeded by a switch, Which can
be either a dash <-> or a slash </> and options must be separated
by a single space.
Example: PK2CMD /1 /PPIC16F887 /Fc:\mycode /M
or
PK2CMD -1 -PPIC16F887 -Fc:\mycode -M
Any option immediately followed by a question mark will invoke
a more detailed description of how to use that option.
Commands and their parameters are not case sensitive. Commands will
be processed according to command order of precedence, not the order
in which they appear on the command line.
Precedence:
-? (first)
-D
-P
-A -F -V -W -X -Z
-C
-U
-E
-M
-Y
-G
-I -K (last)
The program will return an exit code upon completion which will
indicate either successful completion, or describe the reason for
failure. To view the list of exit codes and their descriptions,
type -?E on the command line.
Regards Wolfgang
range is not used
path is not used
memory regions:
P = Program memory
E = EEPROM
I = ID memory
operation.
P = Program memory
E = EEPROM
I = ID memory
by a single space.
or
Precedence:
-? (first)
-D
-P
-A -F -V -W -X -Z
-C
-U
-E
-M
-Y
-G
-I -K (last)
Regards Wolfgang
saschech@gmx.de
Hallo everybody
Thankyou for the help!
So i program my board outside v4 with pickit2,there i can do it!!!!!!!
Regards Wolfgang
Regards Wolfgang
