Using MPLAB with CCS compiler to generate hex file to ECIO40
alazaro
Post by alazaro »
Hi all!
I would like to know if it's possible to generate the hex file with the MPLAB and CCS compiler for the ECIO40. Having the hex file I'll flash the ECIO with the ECIO programmer (ECIOProg.exe).
I've try to do that with no success and I read from the ECIO Getting starter that the code should resides after location 0x800.
The CCS already supports PIC18F4455, isn't the same memory configuration used by the ECIO?
Thanks in advanced,
Γ‚ngela
Ângela
alazaro
Re: Using MPLAB with CCS compiler to generate hex file to ECIO40
Post by alazaro »
Ok!!!
If anyone ahve interest on this.
I found out that is possible.
Γ‚ngela
Ângela
VHDL
Flowcode V4 User
Post by VHDL »
I'm interest ...
