Hallo Benj
If i want export a macro i become a runtime error and flowcode is closed,
the same error if i want delete a lokale variable!
Regards Wolfgang
Microsoft Visual C++ Runtime Error
saschech@gmx.de
- Has thanked: 1 time
- Been thanked: 26 times
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Microsoft Visual C++ Runtime Error
Does your program use arrays? If it does, then this is a known problem and has been fixed in v4.1, which should be released at the end of this month.
saschech@gmx.de
Hallo Steve
Work with a real project with v4 is nearly impossibly,because flowcode crashed anytime i work with variable.
Is there a way become a update for this problem bevore end of the month,because on crash my new data are lost !?
I have a activated full V4.
Regards Wolfgang
Regards Wolfgang
- Steve
Hello Wolfgang,
I received your program - thanks.
I can confirm that this problem is known and has been fixed in v4.1
The problem will occur if a variable is deleted and there are array variables in your program. The workaround is to avoid deleting variables if you have this issue. v4.1 will be released in the next few weeks.
