Help
jawier
Help
Post by jawier »
How i can create a component ccp? I've been watching the Multiservo2 and the requency counter but I can not do a tachometer.
MultiServo2.fcf
(8 KiB) Downloaded 580 times
Re: Help
Not sure if this helps. I successfully created a tachometer for two separate motors by:
1) using port B interrupts with weak pull-ups to monitor the taco outputs and count one on every port change detected..
2) Use Timer0 to interrupt every second. When 1 second has elapsed. RPM (assuming one single magnet trigging hall effect device) = count * 60.
Count is reset as soon as RPM is calculated.
