Hi All,
I'm wanting to change from a pic 16f877 to a 18f4455. I'm wanting to use CAN bus. The 4455 has the relevent connections but are scattered over ports b and c. Can flowcode still use the interface and which port do the CS and INT connect to? Do I need to do anything special in Flowcode?
Jim
18F4455
Re: 18F4455
Hello Jim
Yes the 18F4455 has a rather strange setup for the SPI peripheral.
Flowcode will function fine using the CAN interface and the CS and INT pins are connected to PortB rather then PortC.
That should be it you dont have to do anything special just select your target, add your component and away you go.
