Zigbee component to connect with ECIO40
alazaro
Post by alazaro »
Hi all!
I would like to know if you have a zigbee/bluetooth component that can connect with the ECIO40 directly.
What I mean is, for example, is I can connect the E-blocks Zigbee board – Router directly with the ECIO40 and communicate, for example, with a PC using a another zigbee/bluetooth component.
Thanks for your atention, any replys are welcome!
Γ‚ngela
Ângela
Re: Zigbee component to connect with ECIO40
Both the Zigbee and the Bluetooth E-Blocks will work perfectly with the ECIO devices.
They should be connected to PortC if using the PICmicro ECIO devices and PortA if using the ARM ECIO device.
misoct
Has thanked: 8 times
Been thanked: 17 times
Post by misoct »
Hello Benj
when I connect ZigBee e-block with Ecio I found that the port c pin 3 is not found related to sleep mode and the compile the failed to the chip
thanks
Hello Misoct,
The ECIO module does not have pin RC3 as it is used for the USB regulator pin. Pins C4 and C5 are used for the USB communications. You will need to use the patch system on the Zigbee E-block to move the connections around so that you are not using pins RC3, 4 or 5.
misoct
Post by misoct »
Benj wrote:Hello Misoct,
Hello Benje
thank you for your reply
I used the following pin connection as following
RTS RC0
CTS RC4
sleep RC1
the program works well without any problems
thanks
ec.fcf
(14.5 KiB) Downloaded 575 times
