I am trying to use the CAN component with a 18F8490 but when I try to compile I get:
Panel8490a.c
Starting preprocessor: "C:\Program\Matrix Multimedia\Flowcode V4\BoostC\pp.exe" Panel8490a.c -i "C:\Program\Matrix Multimedia\Flowcode V4\BoostC\include" -d _PIC18F8490 -la -c2 -o Panel8490a.pp -v -d _BOOSTC -d _PIC18
Panel8490a.c(458): Illegal redefinition of symbol: TX1IE
Panel8490a.c(459): Illegal redefinition of symbol: TX2IE
Panel8490a.c(468): Illegal redefinition of symbol: TX1IF
Panel8490a.c(469): Illegal redefinition of symbol: TX2IF
4 errors detected
Error: preprocessing error
failure
Return code = 1
FINISHED
Any ideas what I need to do to get it to work?
18F8490 and CAN
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: 18F8490 and CAN
This is because the definitions in the CAN component are interfering with the definitions int he internal CAN module for this device. Note that the CAN component in Flowcode only works with the external MCP2515 CAN chip and does not currently work with the internal CAN module of some chips.
To work around this problem, you should be able to safely comment out the problematic "#define" statements in the CAN component's C code file. A modified file is attached.
- CAN_Code.c
- (37.51 KiB) Downloaded 573 times
