Hallo Benj
The component`s on the panel first i must select with a short click left and than i can show a reaction on the next activity.
curiously,one of the switch show reaction only after many clicks but not alltimes the same.
Regards wolfgang
Panel in V4.1.1.55
saschech@gmx.de
- Has thanked: 1 time
- Been thanked: 26 times
saschech@gmx.de
Re: Panel in V4.1.1.55
hallo
After i test again i found:
If i place the switch in a greater distance, the effect klick often for select,is not coming.
ore
if the swich is very near to the ather,if i select before a ather switch with a greater distance,it works.
first click for select,second click for work is the same.
Regards wolfgang
ore
Regards wolfgang
Last edited by saschech@gmx.de on Mon Aug 17, 2009 9:41 am, edited 2 times in total.
saschech@gmx.de
A little contemplation of the "panel":
If you work before with the panel from "profilab expert " then ........
Regards wolfgang
Regards wolfgang
- (150.43 KiB) Downloaded 1533 times
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
We've fixed this behaviour in the panel now, but we will not release this just yet. I have just got back from 2 weeks holiday and I've got a lot of catching up to do.
I've not seen Profilab before. It looks like LabView.
saschech@gmx.de
Hello Steve
"We've fixed this behaviour in the panel now, but we will not release this just yet." Why not ?
The same question for the other bug`s , because work with a graeter projekt , for me is a imposition! e.g locale variable ...................
Regards Wolfgang
Regards Wolfgang
- Steve
It takes a fair amount of time to put together a new release, so we prefer to keep the releases to a minimum. We are currently responding to a number of issues and will release an appropriate patch when the time is right.
