Panel
saschech@gmx.de
Has thanked: 1 time
Been thanked: 26 times
Panel
Post by saschech@gmx.de »
Hello Benj
Currently i have loost my panel again.Size in the properties window = 0
Before , i note the fellow change on the panel-window:
The auto-hide symbool loost.
The panel tab-change from the left down to the right upper side place.
Where i can change these?
Regards Wolfgang
on the left side top.gif (15.59 KiB) Viewed 7056 times
(80.78 KiB) Downloaded 1629 times
(58.76 KiB) Downloaded 1629 times
saschech@gmx.de
Has thanked: 1 time
Re: Panel
No answer ?
Regards Wolfgang
Re: Panel
Hi Wolfgang,
Sorry, but I don't fully understand your request. I hoep this answer helps:
It looks like you have attached the panel to the left hand side of the workspace and set the autohide on. You can attach the panel to any edge of the workspace by dragging its top bar.
The autohide feature can be changed by clicking the drop-down arrow on the panel's top bar or right-clicking this bar.
saschech@gmx.de
Has thanked: 1 time
Re: Panel
Hallo Steve
I do nothing the change is coming self.
"You can attach the panel to any edge of the workspace by dragging its top bar".Exactly these i can not do!
If i select docking than i have three symbols in the blue-panel-bar. If i change to "floting panel" there are in the blue-panel-bar no these 3 symbols!
Regards Wolfgang
sa_ecio.fcf
(109.29 KiB) Downloaded 332 times
Re: Panel
Hello Wolfgang
I managed to recover your panel in your attached program by clicking on the View -> Panel menu item.
saschech@gmx.de
Has thanked: 1 time
Re: Panel
Hello Benj
These i now!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
itΒ΄s no my problem of my question.a little bit i think i understand software..........
You can changing the panel tab ?
Regards Wolfgang
(20.15 KiB) Downloaded 1534 times
(18.7 KiB) Downloaded 1534 times
saschech@gmx.de
Has thanked: 1 time
Re: Panel
Hello Benj
The question differently worded,where can i tab-position change?
Show in the screenshotΒ΄s.
Regards wolfgang
saschech@gmx.de
Has thanked: 1 time
Re: Panel
You have my question is not understood,or do you not to answer?
Regards Wolfgang
sisasu
Flowcode V4 User
Re: Panel
Post by sisasu »
I have the same phenomena with v4 console. What can i do to restore old condition?
Regards sisasu
Re: Panel
If you have programs where the panel has disappeared and you cannot get it back, please post the programs here (or via PM) and I will see what the problem is and try to get the panel back for you.
saschech@gmx.de
Has thanked: 1 time
Re: Panel
Hallo
I have the answer found, the Panel-Tab changes to the side,in which i the Panel will move "auto hide".( above-bottom-right or left side).
Regards Wolfgang
