I have now got Flowcode 4 for PIC up and running with the Microchip PICkit 3 device.
Please see this FAQ topic for more details.
http://www.matrixmultimedia.com/support ... =1197#1197
PICkit 3 Support for V4
saschech@gmx.de
- Has thanked: 1 time
- Been thanked: 26 times
Re: PICkit 3 Support for V4
hello
Nice to read,but i give after the responds:
Hi Wolfgang,
PICkit3 does not seem to have a command-line interface to allow us to use it with Flowcode - it only seems to work with MPLAB. While researching this I found the following on the Microchip forum:
the pickit 3 back und buy a pickit 2.........
Regards wolfgang
Hi Wolfgang,
Regards wolfgang
Yes Microchip have now released the command line programming tool for the PICkit 3 so we have now been able to support it in Flowcode.
- tmd_63
- Flowcode V4 User
- Has thanked: 9 times
- Been thanked: 1 time
I have just got the pickit3 to work within V4.2.
If you check your installation and see if you have a pickit3 directory under tools in flowcode 4.
If you have this directory with PK3CMD.exe then all you need is to change your chip compiler option s to the following:
Programmer:
C:\Program Files\Matrix Multimedia\Flowcode V4\tools\PICkit3\pk3cmd.exe
Parameters:
-P%p -F%f.hex -M -V5 -C
Just watch for the -V option. V5 is to set the pickit3 to 5volts. If your device is 3.3V then you must change this to V3 before programming.
-C checks for a blank device and -E (not shown) will erase the device before programming.
I hope this helps.
Programmer:
Parameters:
I hope this helps.
saschech@gmx.de
Hallo tmd_63
You have also the config-line for programming the chip with "preserve EEPROM on Program?
I found:
M<memory region> Program Device
memory regions:
P = Program memory
E = EEPROM
I = ID memory
C = Configuration memory
B = Boot Flash Memory
If no region is entered, the entire
device will be programmed.
but i dont no........
regards wolfgang
I found:
memory regions:
P = Program memory
E = EEPROM
I = ID memory
regards wolfgang
