setting Timer-0 offset in C
rmr
Post by rmr »
I thought this is no problem.....
I wanted to set the offset of TMR_0 to a value of 240 in an Interrupt-Subroutine in Flowcode V4 for PIC
The properties of Timer 0 don't allow this. So I tried to use C-Code in a C-Code window like
tmr0=240;
(As I saw somewhere here in the forum)
I got this messages:
------start messages---------------------------
Starting preprocessor:.......
error: unknown identifier 'TMR0'
error: invalid operand 'TMR0'
error: failed to generate expression
Balancer 16_test1 aus 16c mit TIMER0 Startwert.c success
failure
------end of messages---------------------------
(I also tried tmr0, tmr_0, TMR_0 ....)
Thanks for a reply
rmr
Re: setting Timer-0 offset in C
What chip are you using??
rmr
Post by rmr »
Hallo Steve,
I am using Eico 40pin.
Does this depend on the chip? I thought all PICs are using this Interrupt the same way.
Thank You for your Help
rmr
The names of the registers change depending on the device family.
For the ECIO40 you need to use register name "tmr0l"
In C code this is:
tmr0l = 240;
rmr
Post by rmr »
Thank You for your quick Help!
It works!
I have seen this command already, but I always thought the last character is the Number "1" but it's an "l" (lowercase of "L"). In Courier it looks just the same!
rmr
