Timer 3 int
Mikat
Has thanked: 7 times
Been thanked: 36 times
Timer 3 int
Post by Mikat »
Does Flowcode4 support timer 3 interrupt?
I tried edit the fcd file,like in flowcode3 but i didnt get the timer3 interrupt at the interrupt list.
So how can i use timer3 interrupt? I need timer3,because 0 and 2 dont give enought low interrupt rates,and the tmr1 is used other thing.
And is there way to limit a floating point calculation precision,like 1,2 or 3 decimal?
Mika
Re: Timer 3 int
Hello Mika
Which target are you trying to enable the timer 3 interrupt on? As far as I am aware I added the timer 3 interrupt to all devices that are capable of using it in V4.
I dont think there is a way to limit the precision of the floating point maths but you may be able to add an extra section of code to allow you to do this.
Mikat
Re: Timer 3 int
Post by Mikat »
Target is 18F4620,i get the tmr3 int working at fc3,but not in fc4.
I dont really need the limit the fp precision,but is there "easy" way limit the number behind the dot,so that i can print the float value like 12.7 not 12.7563..
Or is the only way to get float back to int,and to it in int numbers?
Re: Timer 3 int
The interrupt should be allowed to work if you like attach your FCD file to the forum topic and Ill have a look for you. One think to check is the overall number of interrupts specified at the start of the [Interrupt] section.
Thankfully I anticipated this float request. The C code call that is generated for the Float to string function looks like this when my float variable is named f and my string variable is named s in Flowcode.
FCI_FLOAT_TO_STRING(FCV_F,6,FCV_S,FCSZ_S);
Flowcode defaults to 6 characters of precision when using the function in the string manipulation icon. You could use a C code icon to change this.
This would give you one character of precision.
FCI_FLOAT_TO_STRING(FCV_F,1,FCV_S,FCSZ_S);
Mikat
Re: Timer 3 int
Post by Mikat »
Great,thanks Ben.
Can that be used multiple times,eg. adjust the precision do one calculation in 2 decimal precision then adjust the precision again,next calculation in 3 decimal etc..
Re: Timer 3 int
Hello Mika
Yes you can use as you wish in as many different combinations. The Flowcode function will always use a value of 6 but if your calling the function from C then you can specify any value you wish (within reason). We picked 6 as a default as this works quite nicely for GPS.
